AB DF1 driver in Siemens ProTool/Pro
Imi'ike
Jul 2004
Western Michigan
243
I am having trouble using ASCII text with the Allen-Bradley DF1 driver in Siemens ProTool/Pro. I am using a TP270 – 6” and an Allen-Bradley SLC 5/04. I have the driver working and the TP270 and the SLC 5/04 communicating. I am successfully passing data using the B, N, F, I, and O files. However, I can not get the ASCII text files to transfer – that is, the ST file in the SLC.
In the ProTool tag properties window, I have selected the PLC just as I have with the other file types. The type is ASCII, the file type is A (it is the only one that allows ASCII), the file number as 10, the element as 0, and the length as 4.
In the SLC program I have ST10:0 with four characters.
When I load the TP and SLC and go to the screen with the output field, the TP displays an error window with the following number and message:
190004
Tag PlcVersion: PLC address error
Where “PlcVersion” is the tag I created.
Does anyone know how to get Allen-Bradley DF1 driver in Siemens ProTool to read an ST file in a SLC5/04?
Hello,
Instead of using ST - string type file try using Ascii - A type
file in the SLC500 data table. You have selected A in the Pro tool
so you need to match it with A in the SLC500.
For all practical purposes there is very little difference between
A and ST in the SLC500. In fact if you need to use ST just move ST to A before reading it.
Thanks Jiri, your instructions were terrific and my project is working as I wanted. I had never noticed the ASCII data file type in RSLogix before.
Trying to recover an old well controller ML1000 using DF1 Half Duplex and my RSLinx won't allow me to create a DF1 Polling Master Driver. I am...
1,496
I no longer have an option to select df1 path and was wondering if anyone has ran across this. I can configure in RSLinx Classic and see the PLC...
2,048
I am trying to configure driver RS-232 DF1 device for AB SLC 5/04 plc through RS link but its showing error "Failed to find the baud & parity ...
5,959
I am trying to hook up a GE QuickPanel View to an Allen Bradley MicroLogix 1000 via serial. Once I load the runtime into the View I get the...
4,493
Hi Everyone, I want the Allen Bradley driver for interface the elipse scada. I also went to the elipse site,but I am unable to download the...
3,078
