QuickPanel View DF1 driver error
rgraley1
Oct 2014
Charleston, WV
I am trying to hook up a GE QuickPanel View to an Allen Bradley MicroLogix 1000 via serial. Once I load the runtime into the View I get the following error message on the View:
DF!- 32 bit driver (DSV00100) encountered an error. Description: DF1 Module for allen Bradley driver. The driver uses DDK NextGen Tree Version 3.00.0.057, Feb 15, 2000
Driver log file:
2014/10/06 09:19:37 --> Cannot read the SLC I/O configuration table.
2014/10/06 09:19:37 --> Slot (1) is not found (Point (I1:1/3)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (I1:1/3)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/0)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/0)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/1)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/1)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/10)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/10)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/2)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/2)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/4)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/4)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/5)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/5)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/6)). Point is discarded
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/7)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/7)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/8)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/8)
2014/10/06 09:19:37 --> Slot (0) is not found (Point (O0:0/9)). Point is discarded
2014/10/06 09:19:37 --> Error Parsing (O0:0/9)
Any ideas????
I suggest that you update the Driver.
First, you should verify that your version of PME is up-to-date.
Linked here: PME Update Links
What version of Proficy ME are you using, it will dictate the driver's version. PME 8.50 is current. Some of the older versions had "issues" with that driver.
Having trouble connecting and uploading from a Quickpanel View to Proficy Quickpanel communcates to PLC no problem Quickpanel IP...
2,461
I need to try to get an upload from a GE Quickpanel View HMI, IC754VSI06STD-KH, model: ES0611. I saw the thread...
2,783
Hi I'm using GE Quickpanel view and we usually opy the project to cf card and transfer it to the new when we have issues. This time, I need to...
3,721
Hello, I was wondering if any of you have came across this issue I am having. I can download to a 12" IC754VSI2CTD-KJ with my old Windows 7 laptop...
1,935
I'm looking to implement some complex recipes within a GE Quickpanel and noticed in the help files that it's possible to use equations within the...
2,233
