GE Quickpanel View Upload
dearannie21
Aug 2017
Illinois
Hi
I'm using GE Quickpanel view and we usually opy the project to cf card and transfer it to the new when we have issues.
This time, I need to modify the program and do not have any backup file.
Can I upload the file from the HMI.?
If so, how do I do that?
So far, I can connect to HMI via ethernet
In my experience with the QP View, you cannot upload the project - as per the old Quickpanel, and other Rockwell devices.
As you have indicated, I too need to re-download the application on occasion.
I would suggest that you scour the plant or contact the machine manufacturer for the swxCF file, and restore the project to a licensed laptop - there is no way around it. It is also sometimes hiding as a conventional Zip file. The software requires a license in order to open/manipulate the application.
You can only upload from the Quick Panel if the original programmer chose to allow it.
Assuming you have Proficy Machine Edition software, start a new project with the model of QP you have installed. Then upload from the connected HMI. You will need to have a licensed copy of PME to be able to save the file you upload.
Steve
Thanks for the explanation.
I kept trying to upload file from HMI, but no success.
I guess I need to make from scratch.
Again, thanks for your help
I need to try to get an upload from a GE Quickpanel View HMI, IC754VSI06STD-KH, model: ES0611. I saw the thread...
2,785
Having trouble connecting and uploading from a Quickpanel View to Proficy Quickpanel communcates to PLC no problem Quickpanel IP...
2,464
Hello, I was wondering if any of you have came across this issue I am having. I can download to a 12" IC754VSI2CTD-KJ with my old Windows 7 laptop...
1,936
I'm looking to implement some complex recipes within a GE Quickpanel and noticed in the help files that it's possible to use equations within the...
2,234
Hello, I have a GE quickpanel panelview. OS Version Windows(R) CE .NetTM v7.00 The manual says to enable VNC goto: Start -> Programs -> System...
2,494
