Siemens Program Documentation Translation
Fitz
Aug 2005
In front of my laptop
92
We have a new customer who has several S7-400's with programs that are documented in German. They would like us to translate them into English. Is there any easy way to do this, or even relatively easy? Am I stuck with a word by word lookup and translation? Thanks for any insight.
There is no easy way.
I use Google translate text. I was using it this week to support someone in Italy. I have an Italian translator but she wasn't required most of the time.
Google translate text will work for most things but you should still get a German to English translator ( a real person ) to sanity check the results. German and English have idioms or sequences of words that don't translate well.
"What kind of a car is that" translates to "Was für ein Auto ist das?" which if you translate word for word means "What for a car is that?". That blew my away in German class and I will never forget because I missed that on a test. That is when I first became aware of idioms. There is know easy way to translate the idioms and slang. You just need to know them.
BTW, Google translate text got that right.
Thanks Peter. We may try this instead of contracting with someone who knows German. However, it might be good to have someone available to call if we run into a technical term or idiom that doesn't convert in the software.
For fun, I translated "Dude, where's my car?" and it returned "Ey Mann, wo ist mein Auto?".:ROFLMAO:
I also found Yahoo has a similar translator called babelfish.
Good luck with that, the fish really doesn't do well for technical translation.
I remember a translated article that kept on mentioning something about "harbors". It took me awhile, but I finally realized that it was talking about serial ports. LOL
If nothing else, it'll be funnier than all get out.
Edit: I gotta learn how to proofread...
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
174
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
241
First of all, it's a pleasure to join this community, I already have a few years of exp in this sector but never registered on a plc forum, so...
793
Hi, There's a problem I face with upgrading the OS from XP which has the Step 7 Lite installed to windows 10. As I can't use a cracked version of...
623
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
947
