Siemens Program Manipulation
nomsz
Oct 2012
Cebu
Hi All! I have been programming using A-B & Rockwell Software for the past 18 years. Just recently, our company received a programming job for a food factory with Siemens CPU 319-3 PN/DP. Everything was going well till I hit a major bump in programming. The program used a lot of multiplexing & indexing and I'm having problems tracing the source and destinations of certain files to a certain degree, but most of it comes to dead end o_O . To top it all off, all comments are in German šŸ™ƒ . I need help tracing these "dead ends". Tips anyone?
Hello nomsz;
Bayeibrahima's praise is misleading, in as much as we have many experts on hand in the Siemens forum ready to help for questions such as yours.
And continue asking on plcs.net, many members are very knowledgeable on Siemens equipment and I have found many answers here that I signaled on the Siemens forum.
Now, about your question: it is true that indexed addressing in Simatic Manager will make the cross-reference unusable, as it works well only with absolute addressing.
However, in the following link you will find a workaround proposed by one of the very active members of the Siemens forum, fritz, replying to a similar request:
https://www.automation.siemens.com/...ow.aspx?HTTPS=REDIR&PostID=297154&language=en
I suggest you create a source file of all blocks to begin with.
To do so, open any block (e.g. OB1), go to the File menu, select "Generate Source", choose a name for the source file (e.g. "All_Blocks"), select all Blocks and click on OK.
Thereafter, open the source file which will now allow you to do a text based search through the whole program for all the indirect addressing related usual suspects (e.g. terms like "AR1", "AR2", "[", "]", "P#" etc.).
If you know the I/O address, you may also want to search for the INT address number of the peripheral input (e.g. 128 if it is PIW128) as well as the HEX address number (e.g. 80 if it is PIW128) in case this is used for example as a parameter for an FC.
I hope this helps and please let us know what you find.
Cheers
fritz
Hope this helps,
Daniel Chartier
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
184
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
257
First of all, it's a pleasure to join this community, I already have a few years of exp in this sector but never registered on a plc forum, so...
805
Hi, There's a problem I face with upgrading the OS from XP which has the Step 7 Lite installed to windows 10. As I can't use a cracked version of...
633
I have converted a Siemens OP7 program to a new Delta DOP107BV. It is all working as expected except for the timer values. I am using MW36 as the...
954
