Siemens S120 Servo parameter to PLC
JDCROCKETT724
Jun 2010
Michigan
249
I am using an S120 Servo with Telegrams 30,105, and 750. This is all working. The question is how do I get the motor temperature (Parameter r35) to the PLC. I setup a free telegram for 1 word on the hardware of the PLC, but I don't know how to tie r35 in the drive parameters to pass that along to my free telegram. :confused:
I am using portal. I think I found it. I had to tie the r35 motor parameter to p2051. I was confused when I saw the drop down with all the PZD's, but found that my 105 telegram was using the first 10 PZD's and my 750 was using PZD 12. I found from my free telegram configuration on the PLC side in the network configuration that it was assigned to PZD 11. So I tied r35 to PZD 11 in the drive configurations and boom. It worked.
Hi all, I am having a machine with old 802d sl siemens controller. I am trying to tune servo by Siemens starter software. Anyone experienced...
69
Hi Everyone, I am new to siemens servo drives, needs some helps and wondering if you can help me. The machine has Siemens S120 Servo Drvie and...
1,647
Hi, I'm programming an S120 servo indexer with s7 classic and wondering if the best way of doing this is with Easypos? Or is there something...
1,974
Kindly, has anyone tried to control Lenze servomotors with Siemens S120 drives ? Any special hints ? Have some concerns for the resolver and servo...
238
Kindly, can we install new Siemens Sinamics S120 motor modules and new 1FK7 servomotors, in place of old types ? Will the old motion control...
1,127
