Siemens S317-2 DP AND S414-3 PN/DP data -I/O transfering?
Phillip12
Jul 2009
AL.
I have two working Step7 cpu's that control a conveyor system connected plc to plc via net Profibus. The S400 is addressed 3 and the 300 is 4. I need to send the status 1 or 0 of a input 48.1 from the S300 to the S400 and control a output 51.6. I am taking the status of a selector switch and controlling a alarm horn any help would be appreciated. Thanks Phillip
I am not sure what exactly you want to do.
But If you want to read I 48.1 from S7-300 and use it in S7-400 here is one possible variant:View attachment S7-416_s.zip. This is an example of S7-comunication via Profibus between S7-400 and S7-300. It read IW48 and write it to db1.dbw0.
It's one of the easiest way for me
Regards Mitko
Hi! What is the way to convert the code from the Codesys code to the Tia Portal? Regards, WK
22
Good Afternoon , It has been decades since I have done anything with Siemens . What is the Siemens name of their Servo Product Line and what...
205
I'm using the Siemens PRONETA software to do some IO testing currently. I love the simplicity and fast testing capability. Does anyone know about...
85
Hi, First time user of S5 Siemens. Is there any solution on how to solve this kind of error. HMI OP7 $613 DB-error No. 11 (0: 15) Siemens PLC...
172
233
