Siemens S5-100u Question
denisps2
Feb 2005
Hello!
Can someone tell my if I need a programmer of some kind to transfer the program from my PC to the PLC, or can i do this wiht the cable that i have whitch connets the pc and the plc.
The PLC is a siemens S5-100U
Denis!
All what you need is your pc and the programmer-cable. You connect one side of the cable with the PG-port on the s5-100U and the other side with your pc. Sometimes you need to swith COM-port from com1 to com2. You can do this by pluging your cable to another com-port or by changing the settings of your S5-project. Further more you need to make an online-connection. This last thing is also something what you need to do inside your project settings.
If it is a socalled Siemens "PG", then there will be an integrated TTY programming port. Beware that it looks like a parallel port (25-pin female D-shell).
Newer Siemens "Field PCs" do not have the TTY port for programming S5 PLCs.
If it is a standard PC, then you will need the serial cable with a TTY converter 6ES5734-1BD20.
If your PC is so new that it does not have a serial port, then there are several 3rd party suppliers of USB/TTY converters: IBH , MHJ and others.
I looked at Siemens site, but could not find S5 manuals to answer my question. I recently picked up an S5-100U PLC with rack and cards for spare...
3,531
dear All, i am working on the step5 of Siemens. after successful upload program and going online but RLO data is not updating. In Tset>Status...
2,083
Hi, I have several 100U CPU's with either broken Run/Stop/Copy switches or broken off/on switchs. Does anyone have a source for replacement...
1,672
Hi all, I need to interface a Siemens S5-100U PLC part number 5ES5 103-8MA03 onto an Ethernet network. Are there any protocol converters...
1,709
We have an old system controlled by a siemens plc s5 with order no. 6es5 102-8ma02 we want use for this system operating panel siemens op25 but so...
2,900
