Siemens s5-95U
NSG
Jan 2013
Newcastle
Hi, I have a machine with a S5-95U plc......with a problem.
Last week we had a fault in an inverter unit, which melted some cables in the panel, I have now repaired all the cables and replaced the faulty unit.
On power up the machine would not run and the red stop LED was lit on the plc.
Having searched this forum I learned how to re load the program from the eeprom:
remove battery while powered up
switch off
drink cup of tea
switch on
replace battery.
this worked green LED lit and all was well until I started testing functions of the machine, another unit faulted and so I shut down the machine and disconnected it.
On power up all was well, did some testing of transformer outputs and the powered down the machine again while I checked a wiring diagram.
On switch on the red LED was lit on the plc and now re loading the program will not change it.
Help.....
NSG
It is absolutely necessary to leave the S5-95 PLC switched off without batteries for at least 5 minutes.
This is the only way to ensure that the CPU undergoes an overall reset.
Perhaps the battery need to be replaced
Can you get on line with any programming software - or are you just reloading from the eeprom?
There are other reasons the fault led may come on - loose modules, for instance.
It sounds like you need to view the "Istack" fault log, for which you need software!
Hi, Thanks
I have waited for more than 5 mins before the resets.
I do not have software to go online, I clearly need an expert to log on for me.
Any suggestions for someone in my area? what software will they need?
Cheers
NSG
Hi, Thanks
Cheers
NSG
Siemens s5 - there are others, "Quadriga" for instance.
I can only suggest t'internet or call any local Siemens integrators you know.
If you loose 24v+ to one of the i/o cards I think the cpu goes out of run. Check it is where it should be.
I may even have a 95u processor somewhere!
I am near Ipswich - so a fair way from you!
Quadriga, now THERE is a blast from the past. Is it still available? I remember looking at the brochures years ago, but soldiered on with the old S5 that
I grew up with since my PG675 days.
My copy comes with a parallel port dongle. I am hoping to replce my S5 plc's this year so I dont rely on a "Windows 98" laptop!!!!!
Hi there! This is something so old and having machine with it....... Last time unit was powered around 3yr ago and it did not work since than...
236
the steps to have a backup from the plc siemens Simatic s5 95u?
2,402
Hello, Dear Friends.I have an Simatic S5-95U PLC,How to upload program from this?. i have PC to TTY cable also and step 5 software too. please...
4,607
Hi, Dear Friends. I have one Siemens S5-95U PLC with EPROM installed in it, i am unable to upload program from the PLC although i have STEP5...
6,226
Hi, I am from Turkey, my name is Bekir, i hope that you may help me, i have scheer cnc panel 99 model recently i have error message on screen "...
2,836
