Siemens S5 CPU944 AND CP524
shaulapto
Feb 2004
Raanana,Israel
53
I have a Siemens S5 PLC with a CPU944(6ES5 944-7UA22) and a
CP524(6ES5 524-OAA41).
The CPU944 module without EPROM and the CP524 module with EPROM(6ES5 373-OAA41).
Could somebody explain me how this two modules work together?
Thanks,
Shaul
The CPU is the PLC brain, this is where the program is stored and executed. The CP524 is a serial communication card to interconnect the CPU to another device or printer.
Thank you for your reply.So the EPROM in the CP524 contains only a communication program and the main program is stored in the CPU944 RAM?
I am abble to access the CPU program with a programming tool like Step5.
How can I access the communication program stored in the EPROM?
The CP524 has a D type 25 female connector.Is this connector also used to download the program using the com535 software package you mentioned?
Do I need also a special programming communication cable?
Where can I find more information and documentation about CP524 and com535?
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
98
300
106
160
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
