Siemens S5 Floating Point Format
deyoungkr
Mar 2005
Does anyone know where I can find a complete description of the S5 floating point format. I am not a PLC programmer but must interface to a number of S5 PLCs and must convert their internal S5 Floating format to IEEE single precision floating point. I especially need information regarding negative exponent and negative mantissa handling.
Here is the format from a siemens manual v=sign bit:
Most PLCs, including Simatic S5 (135U and up) and S7, use the IEEE FP 32-Bit binary memory format to work with REAL numbers:
(-1^s)*(1.f)*(2^e-127) for e=1..254 (normalised numbers) or (-1^s)*(0.f)*(2^-126) for e=0 (denormalised numbers).
Simon, I don't know in what Siemens manual you've found that picture, but that's not what I've found in the on-line help in STEP 7 V5.3. I've attached that info in a PDF file.
Kind regards,
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
45
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
69
Hello to all, I'm just starting with using CodeSys. Immediately, I have noticed that Codesys doesn't use data blocks like for example S7 does...
157
108
329
