Siemens S5 harware
Sidewinder
Apr 2013
Swansea
83
I am wondering please if someone could help me out here please.
I have recently replaced a 6ES5095-8MA04 with a 6ES095-8MA03 for a client as this was what they had as a spare.
I did as much research as I could and could find nothing to tell me that there was a specification difference in the units.
However the 03 unit would not work.
Can anyone provide me with, or pointers to, the technical specs to see if there is a difference, or could it just be that the 03 is faulty, even though, it is supposed to be OK?
Generally it worked fine, about 80% of the machine functions worked, it was just one operation that would not function, all the machine functions are identical, there are say 6 off of them and 5 worked, the rest of the general control side worked fine.
Thanks for any help that can be given.
Sorry for the spelling error in the title, a bit of a typo, and I can't change it now, I mean hardware!
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
295
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
105
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
160
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
197
