Siemens S5 Help Needed
beethoven_ii
Nov 2006
Central England
409
Hello guys,
I'm conversant with Step 7 but a client wants to log cycle times on a machine which is controlled by an S5 plc. I have attached a screenshot of what I want to do in Step 7 and wonder if someone could give me some help on how to write the same thing in Step 5.
Any help would be greatly appreciated.
Regards,
Barry
Here's the Step 7 code produced by the S5/S7 convertor:
Code:
FUNCTION FC 1 : VOID
  BEGIN
  NETWORK
       AN  T 120;
       L   S5TIME#1s;
       SD  T 120;
       A   T 120;
       AN  I 5.2;
       JC  M001;
       JU  M002;
  M001:OPN DB 11;
       L   DBW 2;
       L   1;
       +I;
       T   DBW 2;
  M002:NOP 0;
       A   I 5.2;
       AN  M 10.0;
       JC  M003;
       JU  M004;
  M003:OPN DB 11;
       L   DBW 2;
       T   DBW 0;
  M004:NOP 0;
       AN  I 5.2;
       AN  M 10.1;
       JC  M005;
       JU  M006;
  M005:L   0;
       OPN DB 11;
       T   DBW 2;
  M006:A   I 5.2;
       =   M 10.0;
       =   M 10.1;
END_FUNCTION
Marker bits are addressed with F bits in the English version of Step5 and with M in the German version. Normally you can switch languages without problem if the different languages are installed.
Kind regards,
Could I ask one further question about the solution you posted please. In my sample S7 code I used M10.0 & M10.1 as oneshot pulses. In your solution it say AN F 10.0 Will this act as a oneshot or just an ordinary marker bit?
Thanks, I see it now but I think F10.0 should be true when I5.2 is high and F10.1 should be true when it is low. To do this I presume I'd have to delete the line = F10.1; and add a JU M007 and put M007:AN I5.2 = F 10.1?
Step7 code now tested in PLCSIM, code modified as follows:
Note use of M10.2
Code:
      AN    T    120
      L     S5T#1S
      SD    T    120
      =     M     10.2
      A     M     10.2
      AN    I      5.2
      JC    M001
      JU    M002
M001: OPN   DB    11
      L     DBW    2
      L     1
      +I
      T     DBW    2
M002: NOP   0
      A     I      5.2
      AN    M     10.0
      JC    M003
      JU    M004
M003: OPN   DB    11
      L     DBW    2
      T     DBW    0
M004: NOP   0
      AN    I      5.2
      AN    M     10.1
      JC    M005
      JU    M006
M005: L     0
      OPN   DB    11
      T     DBW    2
M006: A     I      5.2
      =     M     10.0
      AN    I      5.2
      =     M     10.1
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
979
I have a siemens 317-2 and an old GOT1000 (GT1675M - V) I am trying to get the darn things communication and having no luck. I have followed the...
2,239
I need help from anyone with access to run a test on a 414H, 416H or 417H PLC system. The purpose of the test is to measure the communication...
1,312
Hi Guys, I have a Siemens HMI that hangs. It is ESA XB300BF4R070 running on Operating System XWIN7P01EN1 customized windows7 Pro 32-bits...
1,364
Hi guys I have an existing program on a tia 1500 plc which has an IP address of 172.16.23.### which is ok and a gateway of 172.16.22.01 But our...
2,109
