Siemens S5-Jump label
Scrapper
Aug 2010
Porto
I am creating an STL function in a PB. I need to jump a block of code:
C db 208
L dw 16
T dw 18
I need to do a jump and with the bit d14.0 when the bit is set to "1".
The only problem i don't know how to place a jump label in front of the code.
PLEASE HELP! My boss is going to kill me.
Thanks in advance.
Thanx for the Help! (sarcasm rules)
When i try to place a label i get in red text "Label illegal".
I am trying to go from the code to the address with Shift + left.
Can someone with s5 experience help me?
Taken from the S5 programming book, its a long time since I did anything with S5.
A symbolic Jump label can be up to 4 characters, the first must be a letter of the alphabet.
The jump cannot exceed +127 or -128 words, for longer you would need intermediate jumps.
Cannot jump over segment boundaries.
When you enter, is it the same as S7?? i.e. if jump label = ABC, then you enter ABC: for the destination label.
Put the code you want to skip (or not skip) in a separate PB then use the conditional call (misleadingly named JC)
e.g
Code:
A D14.0  (assumes your CPU supports this instruction)
JC PB99
Hi all! I have a client requesting quotation for us to install a jump box for remote updating of 3 Siemens S7-300 PLC's using Simatic Manager...
2,588
So as you may know sometimes I am not the 'genius' that I once claimed to be... I know it may be a shock to some of you but.... I am starting to...
21
5,547
Need to Jump to different Tasks, based on different Bits. Need Logic like this in STL: If Bit1 = 1, Jump to Task1 If Bit2 = 1, Jump to Task2...
28
13,850
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
110
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
155
