Siemens S5 Processor Fault
marcwand
Oct 2007
Istanbul
24
Hey Guys,
So I am lucky enough to be neck deep with an old piece of machinery that is controlled by Siemens S5 gear.
It is here that I should say that my experience lies mostly on the Allen Bradley side of town, but that is not enough to scare me off.
I was forced to reload the PLC program after I found that the memory blocks had somehow became corrupted. The steps I took consisted of clearing out the memory, resetting all of the hardware settings to default, and transferring the program. I really didn't want to clear out the memory and reset all of the hardware settings, but this was the only way I could get a successful download to the processor.
I now have a stable processor communication wise, but the fault I now have is that it cannot see the expansion rack. I get a fault "Delayed Handshake from Peripheral", and when I go to diagnose this fault it points me to the peripheral input load block and the section of code lines up exactly with the first card of the expansion rack.
I feel that perhaps when I reset the hardware configuration settings, perhaps I messed something up to do with the expansion rack and how that is setup.
Either that, or I have some faulty hardware that I will have a lot of trouble finding spares for!!
Does anyone have any experience that they could share with me along these lines??
I am just about to sink into the manuals..
Just in case some poor sucker finds this thread and was stumped like I was, this is what I did following the post above. Somehow I got it up and going again.
This is what I did –
• The problem was identified in the ISTACK pointing to a FB that was loading the state of the input and output cards. In our case it was falling over on a Load of PW32 which just so happened to be the start of the expansion rack.
• We checked the dip switches on the interface modules and all of the dip switches matched the variable addressing desired.
• We powered the rack back up, but we still had the same fault.
• Just for something to try, I changed the order of the load instructions for the input addressing in the FB where the fault occurred. I basically just moved the group of ones where it faulted down the list.
• I compiled the block and downloaded it to the processor.
• Put the processor into run mode.
• The friggen thing stayed in run mode!! Haha..
I then went back into the FB, put the order back the way it was… redownloaded the changes.. and no problems.
Basically all I did was recompile and download the block where the fault was occurring and we no longer have a fault.
Yesterday, I was called to a plant and found a 317 Processor with controlling a process with some problems. They had changed out some ofthe IO...
1,742
Hi folks...I posted this over at MrPLC.com also and thought I'd post it over here too. I have a S7-315-DP processor at work with an SF light...
3,731
We have an application where a PC application needs to exchange text string messages with a S7-300 Siemens processor via TCP or UDP...
2,105
I am trying to only receive data from a device via serial communication. I can read the data through my com port on my computer so I know that it...
1,706
I'm trying to locate the usage of hidden data blocks used only by the processor. The block folder doen not contain this data block. Is there...
1,648
