Siemens S7-315-DP processor fault
ToddM
Oct 2004
Cascade Va.
106
Hi folks...I posted this over at MrPLC.com also and thought I'd post it over here too. I have a S7-315-DP processor at work with an SF light flashing. I could not get the Step7 software to communicate with it so I sent it out to one of our local electronics repair shops but it came back "unable to repair". I can't find anything in the manual that shows just the SF light flashing by itself. Has anyone else seen this and pehaps know of a way to "reset or repair" this processor or should I make a paperweight out of it?
Thanks and later...Todd
Question
Hi ToddM.
Is the CPU in run mode? Do you have distributed periphery or any device connected to your 315-2DP through the DP port (the one on the rigth). Do you have any other red led on other card.
To get the STEP 7 you can contact your local Siemens office. They would give you a 15 days demo or give the name of a industrial software company that is familiar with Siemens equipment.
Best Regards,
Kelkoon
Hi ToddM!
I have never experienced that only the SF light is flashing, but one time I had to set about an S7-416 CPU that had ALL the leds flashing. After a long search in the Siemens site, I found out that I needed to upgrade the firmware. After the upgrade it started to run like a watch. (how is that proverb translated anyway?).
This was not directly an answer to you question, but anyway...
(sorry for my misspellings)
Todd,
I have had something similar happen to me, but it was with an S7 412, SF light flashing and unable to communicate with it, using either MPI, Profibus or Ethernet via the 443-1.
I had to bin it and get a new one, Siemens did take the old one back as part exchange,which gave us a bit of money off the brand new one.
I never did find out what was wrong with it.
Paul
Hi Folks....Kelkoon wrote..
Sorry I didn't make myself clear there, I've already got the Step7 software, I just could not get it to connect with the processor.
Plucas wrote..
I guess thats like DR.McCoy on Star Trek saying "She's dead Jim"
I'll preface this by saying this is the first time I've worked on a Siemens system and I'm fairly unfamiliar with them. I might mess up some of...
29
758
Hi We were having a few power cuts and the CPU would not work. I had to reset the memory and he CPU would read from the memory card and start...
3,182
Hi, Can anyone explain the difference between rebooting a Siemens CPU 315-2 PN/DP, either by setting the switch into stop and back into run...
2,693
Got a call out to a customers site tomorrow. They have the above PLC and accompanying wiring diagrams from Nov 2013. Anyone any idea if you can...
1,431
Controller 315-2pn/dp installed on the bridge crane. Sometimes (1 time in a week or often) change its condition from RUN to Stop mode. I have...
3,597
