Siemens S7 200 EM Expansion Modules
Oct 2006
Ontario
18
Hi, I ususally work with Siemens S7 300 and 400 PLCs, I purchased S7 216 with EM 231 for a small project, does anyone have documentation on configuration of these modules, there is dip switches and I cannot find any information on those. Thank you
Hllo siemenssurplus;
Here is the EM231 dip-switch comnfiguration, extracted from the S7-200_e.pdf manual (download it from Siemens' support website):
Hope this helps,
Daniel Chartier
Analog modules are not configured in MicroWin. The addressing just gets tacked on.
First EM231 AI0, AI2, AI4, AI6
Next EM231 AI8, AI10,AI12,AI14 etc
If your online you can go to PLC->PLC INFORMATION and the addressing of I/O will be laid out as well as a description of errors etc.
Nick
Hi First post here! I admit I am not too used to handle interrupt OBs in Siemens. I have a customer who has been buying a standardized solution...
254
Is there ANY way to expand the memory on a 1200? I have maxed out the memory and went as far as passing memory back and forth from working memory...
3,122
I am looking into upgrading some of my equipment to the Siemens 1217C PLC and need to know if the 6ES7223 Expansion Module (w/ 16DI and 16DO) are...
2,283
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
259
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
142
