Siemens S7-200 PLC and Simatic Panel TP 170A
Groggy
Feb 2008
Lund
I have a Siemens S7-200 PLC and Simatic Panel TP 170A but I can't get them to "work" together.
I can program the PLC with STEP 7-Mirco and the Panel with WinCC Flexible but I can't get them to communicate afterwards.
Before there was a program on the PLC and the Panel and they communicated fine. When I Updated the Panel to 7.2.0.0 and made a program that reads from VD100 I get #########. (It's set to 4.4 on the PLC)
I'm using the MPI cable btw.
I'm kind of new to all this so it's probably something simple =)
I dont know anything about TP's but ill have a stab
Is the cable the same as the one that did work before ?
Have the comms settings on the TP been altered ?
Have the comms settings on the S7s port been altered?
Are you plugged into the correct S7 port (presuming it is an S7 226)?
Have you still got the old programs that "Talked" ?
It's the same cable
the comms settings are the same on the TP
I haven't changed anything on the S7
It's a S7-224 REL 1.12
The old program disapared when I updated the TP, it was programed by Protool, but I don't have that program.
Is it possible/do i need to update the PLC?
Have you got microwin and been online with the plc to confirm the comm port settings i.e. PLC Address, Highest Address and Baud Rate.
If you havent got the old HMI App then how do you know the comms settings in your new app are the same ?
In WinCC Flex i assume you have set the comms up and these are the same as the S7 200 port.
You say you have an MPI cable, i am not sure but i thought the S7's ports were PPI only ?
From the MicroWin Help
Also see (may be of help)
http://support.automation.siemens.com/WW/llisapi.dll?func=cslib.csinfo&lang=en&objid=14188898&caller=view
Just read this and had a question,
Is it the standard serial MPI/PPI cable that is used for this communication or do you need a null modem cable?
Just curious.
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
2,866
Dear Experts, Please, kindly guide me through how to read data from ABB PLC to S7-1200 Siemens PLC. I want to use Siemens S7-1200 PLC to read data...
448
I've got a whole bunch of L8's and a whole bunch of UDTs that use custom string lengths, but can't seem to figure out how to get these to...
532
hey guys here first time for me in this awesome forum actually i have S7-200 connected to Winview HMI and HMI project file has lost and broken...
600
Hi Complete newcomer to S7 so go easy on me... Siemens S7: What cable do I need to connect S7-1200 PLC to HMI? The touch screen is one of these...
2,606
