Siemens S7-200 Upload question
nykommling
May 2004
minneapolis
39
We have a Simatic S7-200 6ES7 214-1B01-0XB0 (relay output) that has a bad output. I want to reprogram to use an open output. I still have an old PC with STEP 7 and was able to connect to the PLC and upload the program. The uploaded program has a couple of the subroutines that show INVALID 2, INVALID 3 and so forth. I'm wondering if it's safe to change the bad output to an unused output and download, or will the INVALIDs cause trouble?
Double check the part number, I cant find it... IF I were you I would see if you can find a used one (ebay) as I dont think they have been made for some time and download to that one, or unless your machine is down then take the chance
Are the invalid errors because its empty?
Its been a while since I played with the 200's
The machine is down. No spare is available in our plant. I have to decide if I wait for one to be delivered or take a chance and download.
So make a copy of the program and try deleting the networks, looks like there is just an error because they are empty
Also if the machine is down then its down and broken so what is the worst case? its still down
You are right, the machine is down either way. I have the PLC out and am going to swap the physical relay with an unused one. I'll know soon if that works.
I made the mistake of just doing upload and changing an output and then found out that you need to upload all blocks along with the main program.
I would double check that all the boxes were checked during the upload and that you got everything out of it.
I am new to siemens and I am trying to backup program from a S7-1200. Firstly I tried to connect using TIA Portal V16, then it shows the program...
2,131
Would someone be kind enough to tell me what software and cable I need to be able to get an upload from a Siemens S7-200 with a CPU214? Its part #...
2,809
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
255
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
132
Hi, I have a 1214 on ip 192.168.0.100. This is connected to other modules through a switch on same network. I need to connect this to a company...
181
