Siemens S7-300 Master and S5 115U slave
Guest
Guest
G
Hello guys,I am communicating a S7-300 PLC as a master with one S5 115U(IM 308C) as slave using Profibus DP.I would like to be able to read all four analog inputs cards (16 inputs each) at the central rack and other four cards at the expansion rack in the S5 PLC from the master S7. So far I have had success reading only three AI cards.Is there some body out there that could help me on this?.
Thanks a lot
Eduardo
113
Hello Guys, I have s7-315-2 PN/DP with integrated DP. I have no CP module. PLC should be DP master. ON other side there is basler device DECS250...
3,506
I am trying, for the first time, to write values to the control word of a Micromaster 440 using an S7-300 PLC. I barely know what I'm doing, and...
2,575
how can i obtain diagnostic data out of p an f asi master can i use read rec as when using 343-2
5,251
Hello all. I have an ESA HMI that is connected to a Simatic S7-300 (CPU312). I have uploaded the program from the PLC which is written with Step7...
1,467
