Siemens S7-300 OPC - basics
DRL
Sep 2006
Bergen
Hello all,
We are producing a stand-alone product with its own control system, using a siemens 315-2 PN/DP cpu. The only interface to the customers control system has usually been hardwired (start/stop/fault). Now one of our customers wants to read status/alarm bits and a couple of analogue values from our system and display it on their PCS7 system using OPC via ethernet. As the cpu we are using already has ethernet (connected to the hmi panel via ethernet), can I use the existing hardware, or do I need to install a separate CP for this?
I have never used OPC before so I don't know much about it, do I need to setup something in our PLC to make the connection work, and do I need any extra software? Our customer is of course doing the programming of their pcs7 system themselves, so I just have to make sure our PLC has the correct hardware/software/setup to accomodate for this OPC connection.
Any help is greatly appreciated
Sorry if this has been covered in a previous topic.
Regards,
Andreas
Hei Andreas.
You can use the onboard PN interface, no need for a CP.
All the customer needs to know is the IP adress of the PLC, and which adresses to access in the PLC program.
Hi Guys. I hav an general question about data traffic between CPU and CP on K-Bus backplane. We got an issue where a vendor has an S7-300 cpu...
2,323
Hello All, I am having trouble setting up a S7-300 MPI connection using Simatic Manager 5.5. I am trying to use an OPC server with a S7 MPI...
3,905
As a part of the final year Bachelor Thesis project I and two others are involved with, I have been tasked with setting up an HMI/SCADA system...
8,662
Hi all what is the easiest way to get data out of an S7 and an S5 so it is available via OPC? I know that in AB speak, that RSLinx can act as...
2,166
I'd like to know what OPC Server can use with S7 300 cpu via cp5611 profibus/mpi or pc adaptor card Thank you
8,418
