Siemens S7-300 PLC blink light command
radfahrer
Nov 2006
Boston
156
Does anyone know if there is a way to identify an S7-300 PLC by blinking the LEDs? I'm working in a development lab and we have a bunch of processors and aren't sure which is which right now and are looking to identify them.
On a related note, where is the best place to find the MAC ID the Processor or CP module is using. Another engineer I'm working with says that Siemens allows the MAC ID's to be reset to follow the one in the project, so using MAC ID won't be helpful in this case, but I'm looking for it for future reference for systems where they're not doing thaat.
Any assistance appreciated...
-Greg
Yes, there is a "blink" function for anything that is connected via Profinet.
In the Simatic Manager, you open the hardware config and then PLC .. edit ethernet node.
In the dialog there you can scan for reachable nodes. When a list of found nodes appear, you can select one and activate the blinking of some of the LEDs on the module.
Play around with it and you will quickly figure it out.
About the MAC address. I havent heard that it could be resetted. But even if it is possible, why would anyone do that ?
Usually the CPU, CP or IM has the MAC address printed somewhere on the cover.
Flash and MAC ID
JesperMP...
Thanks for the tip on blinking the lights...was able to find it.
Comparing the MAC ID's against what is printed on the module, it does look like they've been changed at this site. As to why they would do that, my colleague said it had something to do with a request from IT...not sure exactly the story behind the IT request though...happened long before I got here...
-G
Hello. There is a problem with Siemens S7 300. We got a replacement PLC but it does not run the program from the MMC. The new PLC is dated 2011...
725
Is there a version of Siemens software that can be used to view only the installed program logic and diagnostic buffer to determine system and bus...
2,124
Dear Friends; We have a BOBST 1228 flexo printing machine having Siemens S7-300 PLC (6ES7 318-3EL01-0AB0) and Lenze 9300 and 9400 drives. The...
2,323
I set the Date and Time of the S7 300 PLC equal to that of my PG. But after a few days I found that the date and time were not what they should...
1,927
Hi Can any one give me some of sample project file for Siemens S7 300 PLC that I can practice at home. Thanks in Advance
2,824
