Siemens S7-300 Programming Hardware
Logix_Stef
Oct 2014
Havant
85
Hi guys,
once more I need your help: Siemens Part Number 6GK1571-0BA00-0AA0, (see the attached image) is this the correct part for uploading/downloading PLC programs? Never been involved with Siemens gear untill recently, to me this looks to much for a programming lead. Or is some sort of converter required to communicate with a S7 controller? Can this be used for S7-200 as well?
Thanks.
PC Adapter
Hi Logix,
Yes this is the PC-Adapter that used to access S7 CPU's.
It can interface to S7-200(PPI Protocol), S7-300 & S7-400(MPI & DP Protocols).
It can be used to Upload/Download the program to/from these CPU's
Regards
Hagos
Hi Logix,
It can interface to S7-200(PPI Protocol), S7-300 & S7-400(MPI & Profibus Protocols).
Regards
Hagos
Thank you very much, Hagos.:site::site::site:
Just for your information, the most recent Siemens S7 PLCs (*) usually have an ethernet port, which you can use for programming.
The PC Adapter for MPI or DP is mostly used with older S7 PLCs.
*: S7-300 "PN" CPUs or S7-300 with CP343-1 module.
S7-400 "PN" CPUs or S7-400 with CP443-1 module.
IM 151-8 CPU.
IM 154-8 CPU.
All S7-1200 CPUs.
All S7-1500 CPUs.
Thanks Jesper,
I just went to check it out: unfortunately only older PLC versions without ethernet port on site. This would have been as easy option.
Thanks,
Stef.
Hi Sir, I am using S7-300/400. I am usually using FC 03 and FC04 to transfer (R/W) bool values by moving them DBs. However i want to R/W bool...
2,061
Hi, I have a 315-2 PN/DP CPU. It was programmed in Step 7 V5.5. Then a colleague programmed it in TIA Portal V13 for a test. Now I want to...
2,279
Hello Guys! Let me explain what is my problem. I have two timers T1 and T2, When i detect a metal the M8.0 memory will addressed and start the...
4,431
Hi I am looking into remote access for modifications/ customer support. I will not be able to VPN so am considering 3G connection with a remote...
4,582
Hi, I am trying to work out some thing with Siemens S-7 Software, Can any body help me with the basic logics & communication setup.
1,625
