Siemens Programming S7 300 Timer problem...
arpix
Jun 2008
Novi Sad
Hello Guys!
Let me explain what is my problem.
I have two timers T1 and T2, When i detect a metal the M8.0 memory will addressed and start the T1 Timer. T1 counts 2sec after 2sec on the out T1 will adderss the M8.1 what is the activation for T2.
T2 will count 4 sec. and this is one cycle. T1+T2= 6sec
I need to make that when i detected the metal the counter will start to work, but if the transporter stops working i want to pause the counting. and when the transporter start to work counter will start do count down wher it was paused. If it was stopt on 3 sec that means the T2 will start from 3.1 sec till 4 sec.
Sorry for my bad english and i hope that my explanation is clear.
Thanx, and best regards
I realy need a quick answer :geek:
Hi Sir, I am using S7-300/400. I am usually using FC 03 and FC04 to transfer (R/W) bool values by moving them DBs. However i want to R/W bool...
2,075
Hi, I have a 315-2 PN/DP CPU. It was programmed in Step 7 V5.5. Then a colleague programmed it in TIA Portal V13 for a test. Now I want to...
2,286
Hi guys, once more I need your help: Siemens Part Number 6GK1571-0BA00-0AA0, (see the attached image) is this the correct part for...
2,338
Hi I am looking into remote access for modifications/ customer support. I will not be able to VPN so am considering 3G connection with a remote...
4,611
Hi, I am trying to work out some thing with Siemens S-7 Software, Can any body help me with the basic logics & communication setup.
1,626
