Siemens S7 IEC timer multiinstace declaration
Feb 2008
Skelleftea
Hello!
I intend to use the iec timer SFB4 for alarm blocks. In order not to use up one instance data block for each timer, my intention was to declare the SFB4 as a STAT in the FB from which the SFB instances are called.
However, when I try to declare a STAT of type SFB4, with a data type SFB4, the data type switches from SFB4 to TON and becomes red. This means that the declaration is invalid.
Which error have I made in the declaration? Or is it not possible to declare system function blocks (like SFB4) as multi instances?
The CPU is a S7-314. Step 7 is of version 5.3. Programming is utilized in FBD.
Edit: The block SFB4 appears in Step 7 manager, and I can program it using an instance data block.
Outotec / Per Abrahamsson
You can certainly use SFB4 in the declaration of an FB. I do that regularly.
Maybe it is your symbol list that has gone bad for some reason.
Try to delete SFB4 from your project, and remove the "TON"/SFB4 from your symbol table. Then copy SFB4 anew from the standard library to your project.
Your STEP7 is also a bit old (v5.3). Maybe there is an issue with that.
With the help of a more Siemens-experienced college, the problem was solved. Instead of dragging the SFB from the library, he created an empty box, and then typed "SFB4" into the box. Now it worked!
Something wrong with the library? (Libraries > Standard Library > System Function Blocks > SFB4).
Tried Googling and searching this forum for the answer to this, but no luck, so figured start a new post to see if anyone can help me...or confirm...
3,410
Hi all, is it possible to compare the Elapsed time from an iec timer (SF4) with another value using a compare block.
3,880
Hello, I want to create a FC function that uses SCL code that checks deviation of a controllers actual measured value from its setpoint and then...
7,112
Hi, Im investigating for my work if it is possible to transfer a simple program from Step7 to RSLogix5000. According to the site of siemens this...
8,731
Hi, In one of my projects i am using Siemens Siprotec Numerical Relays (7SJ611,7SJ641,7RW600) for IEC-103 communication with Telvent RTU. I have...
9,486
