Siemens S7 Strings
cjd1965
Apr 2007
UK
1,659
Hi
I have a task whereby I have a DB which is a list of strings which are defined as STRING[25] and there are 100 strings.
I wish to be able to copy 2 strings based on the 'row' within the DB into a totally seperate DB which will display them onto the HMI
ie if i had ints 1 and 6 this would copy string 1 and string 6 into the other db into slots 1 and 2
I am thinking i will need a pointer to do this and am uncertain how to proceed
If possible use SCL, this makes it a lot easier...
Else you can make a function which uses 2 pointers (source and destination) to copy the strings with the blkmov function (SFC20).
There are a lot of threads about pointers...
See example code attached. To make it easier to test, I've created a DB with the source strings in it, and another DB of the same size to contain the destination strings. You can copy any source string number into any destination string number.
Open the blocks folder online and then open DB6 to view the strings that have been copied.
Thanks for your input. I think i will be abl to chop it slightly to suit my purposes.
I dont think i am going to break my neck over pointers because i have been told the new s7 software due at the end of the year wont support stl at all (IEC only)
Cheers
I have a Function Block, FB10, with IN_OUT variables of type string called MyString1 and MyString2. I want to copy MyString1 to MyString2 and...
10,722
Hi I have been using Siemens S7 317 PLC's for quite a while but this is the first time i've had to do anything with strings. I basically need to...
21
13,892
So, my problem is I have a DB of 4 strings of 254 bytes (total of 1024). I need to clear them every cycle (sorta like a buffer I guess). I tried...
1,774
242
155
