Handling Strings in Siemens S7
Thanks L D + Jesper. I get what u mean. I would have about 30 different strings.
I can store them first and copy them to my db when I need to. D'ont know
why i didnt think of this before. Thanks guys
Hi I cant speak for the op but I have had to do this for a customer as a feature for the 'future' when they were going to fit an HMI. Alternatively the system maybe being connected to a scada that is going to pick up that value for logging or visualisation.
Cheers
If you are not using a HMI, what is the purpose of the string ?
Someone needs to invent a nifty "text to voice" output module. And I mean that it should generate the voice sounds automatically by the text. And the output should be line out to an amplifier.
Would be awesome.
Voice selectable "HAL 2001" or "Steven Hawkins".
Maybe for a printer?
Would be awesome.
I'm already doing that. I convert the fault bits to a text file and copy it to the clipboard, where it is annuniciated. Works like a charm
data accessing problem
can u please help on
client and server problem
actually what happen i use tridonic windim net opc server and tca vista i.e over inbuild client
vis opc easy coonect suit
while connectivity its shows good
gives all tag values
but after few second it disappers
so cant recognise exact problem.
and also it shows good connectivity with softing opc client but not allow to read and write access..
what to dooo
please help
I am trying to get Codesys to work with a couple of Moxa ioLogik E1200 series DIO devices (E1210 and E1211). I am able to write to the E1211 DOs...
174
The objective: Reach about 10’ horizontally into a 1300F furnace, and pick up a 140lb rectangular container, then pull the container back out of...
1,874
Hello All, I don't so much have a problem more my OCD. I have a project, with over 1000 alarms. I create arrays in the PLC/HMI for my alarm...
566
I hope somebody might be able to help me who has done some IO-Link messaging using an S7-1500 (TIA Portal 17) and the CMx8 IOLink module for the...
1,795
Just a little bored, so I thought I would start a thread in one way of using recipes in batching processes, I'm aware there are probably many ways...
589
