Siemen's S7300 AC input card delay
becs
Mar 2012
Ontario
20
I'm doing a small project to count misloads on a machine. Three consecutive misloads from any feeder will result in the machine stopping. The machine is an older relay machine, not too complicated, but I'm installing a Siemens 312 CPU to do the counting (there are 14 feeders total that need to be monitored independintly).
The misfeed sensor already exists on the feeders and outputs a 120VAC signal. I will be installing a sensor to detect each load section of the chain conveyor. My worry is that this machine has a little under a second cycle time. I figure the misfeed sensor will only be high for ~0.3sec/cycle and the chain conveyor sensor will be high for 0.05-0.1sec/cycle.
In the past I have generally worked with purly DC machines and I'm a little concerned about the lag time of the AC input cards. Most of the Siemen's AC DI card have a delay of 25mS. If my signals are occuring at regular intervals will this delay cause me a problem?
Has anyone ever got this message before? The drive will be running fine and for a couple days or a week then the control room will get the message...
573
Hi, I am logging tags every 24Hr in table view in siemens WinCC RT Professional. Every day at 7:00:03 AM a value is logged. WinCC takes value from...
17
3,599
Hi everyone. Please help me to upload program from S7-1200 with TIA v14. I created new project, go to Online tab, select Upload devices as new...
1,094
Hello Every one I am trying to connect the encoder with siemen's 300 plc but dont know how to do it... Could some one send me the connection of...
2,220
Hi, Had anyone Have this problem, where the Siemen 226 CPU (s7 200CN) 6ES7 216 2BD23 0XB8 disconnect the Proface Model 3580207-02...
1,202
