Siemens SFC51 to read LED status?
MOeZ
Nov 2009
singapore
101
[FONT=&quot]Can test SFC51 to read LED status with PLCSIM? I will used 315-2-Dp and currently when I tested with PLCSIM, I only got LED ON bit at Index W#16#0004 with SSL ID W#16#0019 when PLCSIM is run and When PLCSIM stop, nothing changes as i don't have stop bit at Index w#16#0005. Could someone guide me out? I tried SSL ID W#16#0074 and return value got error 16#8082. o_O[/FONT]
[FONT=&quot]I have STRUCT my return Data Record at follow. [/FONT]
[FONT=&quot]DR Struct[/FONT]
[FONT=&quot]ID : word;[/FONT]
[FONT=&quot]Led On : Byte;[/FONT]
[FONT=&quot]Led Blink :Byte;[/FONT]
[FONT=&quot]End Struct:[/FONT]
[FONT=&quot]Is that right for SSL ID W#16#0019 too? I am confused with Siemens manual.[/FONT]
[FONT=&quot]TIA,[/FONT]
[FONT=&quot]:ROFLMAO:
[/FONT]
how i can access SF led?
o_O okies and thanks LD again. How do i have access to get SF led status? there are not mention for SF LED Index?
Dear all, I have a question about using SFC51. I used SSL_ID 0D91 to obtain the status of a remote IO panel. When I read through the help file of...
1,592
Hi all, I have got a setup as shown in the attached picture. I am trying to detect state of the slaves, but only the IM153-2 shows up. How can I...
2,429
Hi Folks, Looking for some guidance as I'm starting to struggle! Quick run down on system:- Using 315-DP which is connected to 10 profibus...
4,864
I am using an S7 315DP CPU with 2 x CP343 ethernet cards for modbus over TCP. As part of the project I need to monitor the status of the ethernet...
2,866
