Siemens SFC51
inst_tech
Jan 2010
Scotland
58
Hi Folks,
Looking for some guidance as I'm starting to struggle!
Quick run down on system:-
Using 315-DP which is connected to 10 profibus nodes (encoders). I wish to display on an HMI if they are healthy or not so am using SFC51 to read out the data.
Problem:-
If i use the SSL-ID of W#16#00B4 i can see the first byte change when i "fail" a node however I would like to use SSL-ID of W#16#00B1 but cant seem to read any info. I've changed the index number to the NODE number but unsure if this is right.
Questions (for the gurus out there!):-
1. How do use the SSL-ID B1 correctly, am sure i have the wrong Index number!
2. Is it ok to have for example 10 calls to SFC1 located in OB1 (for each node) while only using the 1 DB Header.
Many thanks.
Inst_tech
Dear all, I have a question about using SFC51. I used SSL_ID 0D91 to obtain the status of a remote IO panel. When I read through the help file of...
1,593
Hi all, I have got a setup as shown in the attached picture. I am trying to detect state of the slaves, but only the IM153-2 shows up. How can I...
2,431
Can test SFC51 to read LED status with PLCSIM? I will used 315-2-Dp and currently when I tested with PLCSIM, I only got LED ON bit at Index...
3,644
I am using an S7 315DP CPU with 2 x CP343 ethernet cards for modbus over TCP. As part of the project I need to monitor the status of the ethernet...
2,866
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
91
