rQx
Part of my problem is I don't use Siemens enough to know where the shortcuts are. So finding anything for me is painful.
I use Rockwell stuff enough that I barely touch my mouse when entering rungs. I do almost everything via command line editing using mnemonics. If I had a good enough memory to remember tagnames I would hardly touch the mouse at all. So, granted, product familiarity is very important. But I still contend that a user coming to a platform cold will have an easier time devising a working system with almost any other plc development environment (including Simatic Manager) relative to Portal.
Keith
true that, portal is a one of a kind program ( so far).
I really like that everything is in one program, it makes it easy to use. Instead of connect tags accross diffrent programs I can just open my HMI part of the portal and choose tags from my program directly into my HMI project. Since I'm not that advanced and have never went to school learning how to program, this is a good feature.
I guess all program have pros and cons. Depending on how mush you work with it, you will either love the one or the other.
