Siemens SI ASCII Card (RS232C) with a barcode scanner
luyolo21
Feb 2015
Port Elizabeth
Hi All,
I have application to read data from barcode scanner to S7 PLC through SI ASCII Card (RS232C). I have tried using the standard FB's to read the data but im not getting any info from my DB's. I used FB 2 (R_RSV) but I can get the Data on my DB's
If you have done this kind of application, please guide me how to setup for this.
Thanx for your response @keithkyll
I's using an S7- 300 plc which does not have the RS232 port but uses a communication module with a serial interface (RS232) (6ES7 138-4DF01-0AB0)
Thanx
You must choose the module with the correct mode and the number of bytes you want to read.
In your case it will be ASCII and x nr of bytes.
Then you must set the settings of the card to match the setting of your reader baudrate/handshake and so on
Hi, I need to send a command from a S7-300 with a CP341 in ASCII format (RS485). I can get the command to send fine, what I need to do is add...
6,265
Hi If I wanted to put a pure RS485 ASCII string into an S7 PLC (not something I have done before) and then pick out a section of this string, how...
2,253
Fellow PLC afficianados, I'm having some difficulties reading registers from a Emerson Coriolis transmitter. The following equipment is used...
4,356
Dear Experts. I have a CPU 315-2dp Siemens PLC which is communication between mistubishi fX-3U Series mistubishi is giving me AScii String data...
5,948
Hello friends, Is is possible to make S7-300 with CP341 to be Modbus ASCII master in communication to some other Modbus ASCII slaves? I found...
2,595
