DLMUK
Hi
If I wanted to put a pure RS485 ASCII string into an S7 PLC (not something I have done before) and then pick out a section of this string, how would you go about doing it?
I assume if I had a 300 I would add a CP340 (my baud rate is 19.2k so should be fine) and then added the Port config and receive data blocks to my project then this would encapsulate the received data into a tag in the associated DB. But how would I then pick out bits of data from the tag with the entire data string in?
