DLMUK
I had RS485 ASCII string going into a CP340 @ 9600baud rate. This was working fine.
I had to change my baud rate to 19200 so I got ripped off for a new input module, CP341, and have connected this to my PLC. I have configured using the P_RCV_RK but cannot get my string input.
I can see the RxD light flashing on my CP341.
I am taking in a raw ASCII string so I have only used the input parameters
EN_R (this is always on/set to 1, also tried with a 1s pulse but no joy)
LADDR - this is my CP341 start address (263)
DB_NO - this is my rcv DB as 26
DBB_NO - 0
DB26 is setup as
DBB0.0 String tag
Note, the config of DB26 is the same for the CP341 as it was for the CP340.
DBB_NO - 0
DB26 is setup as
DBB0.0 String tag
