Siemens tp170a modbus rs485
Emil_T
Dec 2015
Huskvarna
I have a siemens tp170a hmi and tried just for fun, to use modicon modbus driver settings and communicate with a regin roomcontroler. I use the IFB-port and change dip switches to rs485. I read temperature and some other input registers, works fine!
In my house i have 8 roomcontrolers with modbus and now I want to communicate with all of them. I use wincc flexible 2008, and added another modicon modbus connection with a different slave adress. But now I get errors when i generate the project. To many connections. Is it possible to have more than one connection like this to siemens tp170a?
After reading the guide and some test in wincc I found that if I use TP177 i can use 4 connections. With TP170, only 1 connection. Probably because modicon use rs232, point to point...
Hi guys, I have Siemens TP170A with touch non-operative. I have replacement but Touch Screen do not work (cannot set Transfer Mode to make a...
2,324
I am trying to extract an existing program from a Siemens TP170A HMI, using ProTool CS. Thus far, I have been unable to establish communication...
3,435
Hello, Is it possible to upload a project from a TP170A panel to a PC? The "backtransfer" option is not active for this panel in the WinCC Flex...
2,230
Dear friends, I have SIEMENS Touch Panel TP170A which is connected to S7-200 PLC via PROFI-BUS. While installing new Touch screen, it is not...
8,418
Hello. I don´t have much experience about Siemens´ Operating Panels, so I`m asking you the following: I have TP170A and I want to set a...
6,237
