Siemens Step7 Basic HMI compatibility
Blue92
Sep 2019
N/A
27
I have obtained an older copy of Step7 Basic V11 SP1. I plan to run it on Windows 10 through a virtual machine with a copy of Windows Vista Home Premium that I have laying around. My PLC is an S7-1200, and I was looking at options for used HMI's on ebay. I found a 6AV66470AD113AX0 KTP600 for sale locally on ebay and I see online it says it needs Step7 V10.5. Can I use this HMI with my copy of V11? Sorry for my ignorance as I come from an Allen-Bradley/Automation Direct background and know nothing about Siemens.
Hi there. it seems many of the Siemens experts are already in their Easter break, so I will try to help. The link below says that this product is "configurable as of WinCC flexible 2008 SP2 Compact/ WinCC Basic V10.5/ STEP 7 Basic V10.5". I would imagine a newer version such as the one you mention (Step7 Basic V11 SP1) should work, by virtue of being newer, as it says "configurable as of... V10.5". But if you are not in a hurry, maybe it is better to wait for advice from the many Siemens experts in the forum.
https://mall.industry.siemens.com/mall/en/us/Catalog/Product/6AV66470AD113AX0
SIMATIC HMI KTP600 Basic Color PN, Basic Panel, Key/touch operation, 6" TFT display, 256 colors, PROFINET interface, configurable as of WinCC flexible 2008 SP2 Compact/ WinCC Basic V10.5/ STEP 7 Basic V10.5, contains open-source software, which is provided free of charge see enclosed CD
Hi. This screen can be configured in V13 SP2, so I would say V11 will be able to configure the unit. Sorry I can't check V11 directly as I don't have it installed. Steve
I want to test a plc program that i have programmed, now i do it with simulator from Siemens Step7 but that is not so easy because when an output...
7,405
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
146
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
142
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
540
Hi, I received a Step7 Backup from my client and tried opening this backup but it won't open as there seems to be files missing from the backup...
3,019
