Siemens Step7 Project Error
infineum
Mar 2006
Linden
100
When I create a project in Step 7, I get an error when I open the project. The error states "the project contains errors in the internal data structure". The help screen provides this information "S7tgtopx.exe: Internal error
during saving (action 'New user project ') of the data
of server 'p7spomax.dll'." The help states to perform a "save as". I have done this and continue to get this error. I have reloaded Step 7 and upgraded to the latest service pack but still get the error. I am using Step7 V5.3 SP3. Any ideas. Thanks.
I followed your suggestion. I then get another error pertaining to file siprom.lck. I forwarded this issue to Siemens support. Hopefully they will have some suggestions. Thanks.
Follow-up
Just as a follow up to my post.....
The problem turned out to be an installation of an old version of PDM. I installed version 5.0 (I do not have a later version). When I uninstalled this program, my problem went away. The hint was the Siprom file fault when I performed a "Save as" with reorganization.
Hi everyone! I have a question for the Siemens Step7 gurus out there. But first, some background! There's also a TL;DR at bottom if you don't...
5,964
Hello to all members of this thread, I've been trying to compare siemens step7 project online and offline block comparison in ladder. when I click...
6,079
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
146
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
143
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
543
