Siemens STEP7 Software Redundancy
prhudson
Guest
P
banghead
I have been trying to get Siemens STEP7 Software Redundancy to work on two S7-416-2DP PLCs. I have tried copying the demo program, SWR_400_MINI, function blocks with a few minor modification for the hardware that is connected to the PLC. I keep getting an "area length" error that stops the PLC.
I printed out the SWR manual that I download from the web and I have read every page. No help there.
I went to the Siemens site and found a FAQ (ID: 2812567) relating to this problem, but nothing I have tried will get past the "area length" error.
Has anyone had any success with Siemens STEP7 Software Redundancy?
:unsure:
Does your hardware configuration contain analog modules using the process image? I received a similar error message using a S7 414-4H as just an F system (no redundancy). In my case, the default configured process image was too low for the default addressing selected for some of the failsafe I/O modules. I readdressed the I/O modules to fit in the size of the process image and it worked fine. Yours may be a totally different problem that is related specifically to the reduncancy, though. Good luck.
Hi all, I would like to introduce my software for emulation of conveyor systems. This programm provides you to create some objects as conveyors...
1,360
I have an opportunity to quote an HMI project for one of my customers. It's a small project, and the customer is not the type with deep pockets...
24,859
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
147
When you download a DB, the values get overwritten by what is in the "actual" column in offline DB. Does this happen at the start of the PLC...
143
I have a word in some DB which I want to load to AR1 and use as a pointer. In order to do this I need to write L DBxy.DBW xy SLD 3 LAR1 I...
543
