Siemens TD200 problem
ArikBY
Oct 2003
Oranit Israel
1,434
Hello everybody
I have system which include S7 200 and TD200 V3
I need to let the operator to change 2 values
VW0 and VW2.
I follow the wizard but I get the message
NO PARAMETER BLOCK.
I dont have any error when I down lode the code.
I started the subroutines of the TD from my ladder.
Where is my mistake? Whats wrong?
Thanks In Advance
The TD200 wizard stores the configuration data in block memory, the address is by default from VB0 but you can change it. In your case it looks like you are using this area for your program and the TD200 configuration data is stored in some other area.
The 'No Parameter Block' message is displayed on the TD200 when it can't find the parameter block. You have to change the parameter block address in TD200 to point to the correct location.
On TD200 press ESC twice to access the diagnostic menu. From there select TD Setup > Parameter block address. Change it to point to the correct address configured in your program.
TD200 and S7-224.I have TD200 and siemens s7-224 plc.How is the configuration for the td200 done.Pls i need this forum help
Beause Siemens TD200 has been discontinued,I still need to use some of the machinery.I nedd td200 alternatives.Can anyone tell me what the product...
2,311
Hey, I have a TD200 and an S7 200 connected. I set up the TD with the wizard - parameter block starting at VB0. Only have 1 message - enable bit...
1,592
I have an S7 200 plc working on a machine. it's TD200 display is damaged. Now I have purchased a new one. do I have to program it or just install it?
2,382
Im using a TD200 with a S7-200 PLC. I have configured the alarms, and i have set it to default to operator/user screens not alarms at the...
3,822
89
