Siemens TD200 Question
Frosty
Jul 2008
Cork
66
Hey,
I have a TD200 and an S7 200 connected.
I set up the TD with the wizard - parameter block starting at VB0.
Only have 1 message - enable bit 15.7.
I tried addressing the enable bit in a standard ote, and also by using MOVB 16#80 into VB15 - neither seem to work.
When powered up I get the 'No Parameter Block' error. I have the parameter block address at 0.
If I go to view messages i can see my message, but after a while it reverts back to no parameter block. I also display 2 values which I can see in my message, but they do not update until I go out and back in again.
Any thoughts?
Beause Siemens TD200 has been discontinued,I still need to use some of the machinery.I nedd td200 alternatives.Can anyone tell me what the product...
2,311
I have an S7 200 plc working on a machine. it's TD200 display is damaged. Now I have purchased a new one. do I have to program it or just install it?
2,381
Im using a TD200 with a S7-200 PLC. I have configured the alarms, and i have set it to default to operator/user screens not alarms at the...
3,822
Hello everybody I have system which include S7 200 and TD200 V3 I need to let the operator to change 2 values VW0 and VW2. I follow the wizard...
8,803
87
