Siemens Tia Portal v11 Goto? Cross-References? questions
Tommycai
Aug 2011
KY
120
On TIA Portal is there a place I can type in a message like go to in step 7 V5.5?
Also when doing ccross-references with an array address it always shows me the first bit of that array no matter which one I am clicking on? is there a way to choose the bit from the array I am trying to locate?
thanks but the program that I have has to be in ladder logic (Customer specs) I use arrays of bits to output for auto logic but when I try to find the array numbers it takes me to the first number only in cross-referencing.
GoTo statement in SCL equals Jump box in ladder logic.
As for cross referencing of arrays i don't know for sure. but as i recall array is a pointer to a reserved memory space, so program maybe cannot show the offset, just a pointer to start.
Hi PLC people, think about this scenario: The PLC is somehow connected to the same network with the facilities` network. Then someone connects to...
45
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
172
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
475
Hello, If the date on the license manager of tia Portal has expired, can I still work with it? or is this just to keep the program up to date...
235
Hi everyone I've created an FC that includes the blocks TCON, TDISCON, TSEND and TRCV. This block has to be as generic as possible across...
1,555
