Siemens TP177A
silva.foxx
Dec 2004
North Wales; always West to England!
519
Hi...merry Christmas to all.
Quick Q:
Is there a way of putting a Siemens Touch TP177A into transfer mode without cycling the power to the HMI?
If I remember rightly... Omron NT20s had secret buttons in opposite corners of the screen for putting into this mode.
Any info appreciated.
Thanks in advance. Have a great festive holiday and all the best for 2010. Be safe
silva.foxx
I'm fairly confident that there is a setting for 'remote control' that has to be checked to allow transfer without cycling the power. I think if my memory is good there is an option menu on startup that allows you to enter a configuration menu where these settings can be made. It is also possible to add some function buttons to a screen that can force the unit into a setup mode but this would mean adding in some kind of system admin page to the HMI app. Have alook at the manual on the Siemens web site, this is what I remember on startup, pick the control panel option:
Both items Gnook mentioned are possible.
I prefer to add a "Shutdown" button to the screen.
If needed have it only be visible when admin is logged in.
I think it is on the "Transfer settings" screen you can enable remote control, where it will automaticly cycle power when you download even if not in transfer mode. This is fine if your only using 1 HMI otherwise I preffer to put the HMI in transfer mode so I don't download to an incorrect station.
Is it possible to show an image (image which is uploaded to web)on my TP177A operator panel? for example: I want to see http:\\www.abc.com\1.jpg...
2,020
Hi, I have a TP177A HMI screen, i managed to find the project files but i want to make some mods and the project is WINCC 2005 but i only have...
2,874
Does anyone knows what the maximum number of tags is in a TP177A Siemens panel?
1,360
Hey all Been asked to link up a Siemens Touch TP177A (6AV6 642-0AA11-0AX1) to an S5 plc. Obviously TTY at the plc but RS232/485 (DP/MPI/PPI)...
4,490
I've got a Siemens S7 200 connected to a TP177A touch panel. Is there a way that I can can set the touch panel date and time to the PLC time of...
8,792
