Siemens TP270 Ethernet Capability
acargib
Jun 2007
Liverpool
I have a number of TP 270 touch panels with No ethernet ports to connect into. I have heard that either a USB to Ethernet adapter or a CF card to Ethernet adapter can be used to allow ethernet connectability. I have been trying with an USB adapter but it asks for a driver to be installed. Has anyone managed to successfully carry this out and if so how can it be done. I have spoke to Siemens thech support who have not been much help all they will say is that it can be done. Any help would be appreciated.
Many Thanks
From the link:
"The Socket Rugged CF 10/100 card is not NE2000 compatible. NE2000 compatible drivers should function with this card after some small changes are implemented. These changes involve the initialization process and are limited in scope. Small differences exist in the NE2000 compatible register set but these do not affect general operation of the Rugged CF 10/100 card."
I would not waste my time with it. You dont have a chance to do anything.
acargib,
We have 13 OP270's running with the same Socketcom cards.
Only difference I could see between our parts and the one in your link would be the part nr.
Ours is 8510-00093(C), your link has 8510-00263.
Changes to be made looks like it should be made to the driver......
Too bad we don't have one of the recent versions...might've tested it...
Jeebs,
How old are the cards you have mentioned? Looking on the Socket website and searching for that part number is turning up no matches also will it be a factor that you are using OP's instead of TP's?
Thanks for the reply
Hi guys, I have a trainer with a Siemens S7-315 Processor and a TP270 HMI, using an MPI adapter to connect. I have gone over every setting I can...
1,749
Hello everybody! I have a question about PLC CTI 2500 model C200. We have device with this controler but it hasn't a operating panel. I want...
1,837
Hello, A TP270 is giving us some problems when starting up. Namely, the touch function does not work for some time (like half an hour), but the...
3,326
Hi there, I have a TP270-10" Screen that I cannot download to from WinCC Flex 2008... When in transfer mode, the TP270 has "Loader B 6.0.2.23" and...
8,484
Hello to all, My coleague is trying to download project with WinCCFlex 2007. He is using MPI/DP connection and it is OK. But he keeps getting...
4,414
