Siemens TP700 Comfort - language and logging
jumpier
Aug 2005
Piemonte
32
Hi to everybody
i will to develop an HMI application with Siemens TIA Portal v15, on HMI model TP700 Comfot. Two doubt:
- i've configured 3 operator language on the project: when operator changes the language (using 3 buttons), is possible set the language number choise into a HMI internal tag?
- i need to export each hour a list with alarm raise, alarm acknowledge, alarm reset and also who is logged in when alarm raise / ack / reset. Is possibble do this using the basic system function or is required to write a vb script? Do you have some samples / links to share with me?
Thank a lot for any suggestion!!
Bye bye
I think this link may guide you to what you're looking for with regards to language selection.
https://support.industry.siemens.com/cs/document/109478713/how-do-you-use-wincc-(tia-portal)-to-switch-languages-on-a-simatic-hmi-operator-panel-?dti=0&lc=en-WW
You'll have to give more details for your export. Do you want a csv file every hour, for example? Where do you want the information stored?
Thank you for your reply!
My customer ask me if is possible save a report (.CSV file format) each hour on USB support, with different file name (i.e. yyyymmdd_hhmm_archive.csv where yyyy = year, mm = month, dd = day, hh = hour and mm = minutes).
Each file will stored a list of alarms raised, acknowledge and reset in the last hour and (if is possible) the logged user on the HMI.
For the file name, i think be possible by using VB script, but i don't know how to save the alarms "only of last hour" toghetter to the user logged in.
Any idea? Thank a lot
Hello great friends. Please help me....what is the easiest way I can RESET a Siemens TP700 COMFORT HMI Touch panel, to its Default...
1,245
Hi, i need to filters alarms (if is possible) by using the report groups. Also, i need to aknowledge all alrms preset by pressed a graphics...
1,296
Even in the Windows menus. Recalibration does not register pressing either. Workaround VNC client. All touch suddenly gone wo warning and I find...
1,797
Does this panel have built-in to log on %-deviation from last value? I can only find where you define a deadband for each logged tag, but that...
1,126
I'm a rookie PLC guy tasked with getting a TP700 to begin recording after a temperature spike and to stop when the temp drops back to a normal...
2,031
