Siemens TP700 Comfort
WW2010
Apr 2016
TN
I'm a rookie PLC guy tasked with getting a TP700 to begin recording after a temperature spike and to stop when the temp drops back to a normal operational temp. The panel currently records the temps continuously and stores on a USB drive. I've added an input location to designate the spike temp but I'm kinda lost as to the rest. The panel is still constantly recording. Any help would be greatly appreciated.
Thanks, Wes
You can use the system functions StartLogging and StopLogging to control when an archive is logging.
Use an INT PLC tag to control the system functions. You can use the events "On exceeding" and "Falling below" to start and stop the logging.
Set the limit to 1.
Write a "2" to the tag to start logging.
Write a "0" to the tag to stop logging.
Thanks for the help Jesper. It is now logging what I need and when I need it. I didn't go exactly how you explained but your info got me looking where I needed to.
Hello great friends. Please help me....what is the easiest way I can RESET a Siemens TP700 COMFORT HMI Touch panel, to its Default...
1,243
Hi, i need to filters alarms (if is possible) by using the report groups. Also, i need to aknowledge all alrms preset by pressed a graphics...
1,296
Hi to everybody i will to develop an HMI application with Siemens TIA Portal v15, on HMI model TP700 Comfot. Two doubt: - i've configured 3...
2,032
Even in the Windows menus. Recalibration does not register pressing either. Workaround VNC client. All touch suddenly gone wo warning and I find...
1,794
Does this panel have built-in to log on %-deviation from last value? I can only find where you define a deadband for each logged tag, but that...
1,124
