Signal converter: Sinusoidal 1Vpp to square wave
krk
Aug 2004
Kent
795
I have an existing machine with an IFM RN6057 encoder (dat sheet attached) fitted.
This encoder has 2 outputs:
- SSI singleturn
- Incremental A+B (sinusoidal 1Vpp)
The existing control system is using the SSI output and working fine.
I'd quite like to use the incremental output from this encoder but need it as a square wave input into my counter module.
Do any of you guys know of an off-the-shelf converter from 1Vpp to 5V or 24V square wave?
Thanks Keith,
All I managed to find was a Heidenhain IK220 which is a PC based card - don't know how I missed these.
The GEL 213 looks like it could do the job.
Thanks again.
Kevin
Hello guys, can you please recommend a robust and reliable signal converter 0-5V (or 1-5V) to 4-20 mA? I need to measure voltages between mainly...
6,271
hola buenas tardes Tengo que comunicar un lector de codigo de barras con un compact logix a traves de un convertidor de señal 232 balluf que va...
1,332
I need to go from a powered 4-20mA output (i.e. transmitter supplies voltage) to an Allen Bradley HART input card 1756-IF16H. I cannot set input...
2,448
i would like to know if it is possible to convert a 0-10v signal into a -10-10v signal, and how? tnx...
1,521
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
218
