signal converter
Hello guys, can you please recommend a robust and reliable signal converter 0-5V (or 1-5V) to 4-20 mA? I need to measure voltages between mainly...
6,318
hola buenas tardes Tengo que comunicar un lector de codigo de barras con un compact logix a traves de un convertidor de señal 232 balluf que va...
1,340
I need to go from a powered 4-20mA output (i.e. transmitter supplies voltage) to an Allen Bradley HART input card 1756-IF16H. I cannot set input...
2,460
I have an existing machine with an IFM RN6057 encoder (dat sheet attached) fitted. This encoder has 2 outputs: - SSI singleturn - Incremental...
3,704
I am not sure why this is requested, but it was asked. Currently I have one PLC , with one output to a relay, turning on a field equipment (just...
235
