Simaric Panel with SLC 5/04
francisedetz
Oct 2015
Ibadan
29
Hello everyone,
I am trying to create a Simatic Multi Panel touch 10" program to control Allen Bradley SLC 5/04.
I have set the Baud Rate, Parity, Stop Bits, Error Checking, etc to be the same on the WinCC communication connections as I have set in the RSlinx whilst transferring the program to the PLC.
After transferring the HMI program and connecting the RS232 in IF 1A. The HMI & PLC do not seem to have established connections.
Pls what is the best way, or even the simplest way of establishing communication between these two?
And oh.. I used "bit" as "Data type", and "addressed" it to "B3:0/0"
I HAVE B&R POWEL PANEL 400 HMI. THE ISSUE IS HMI NOT BOOTING, DISPLY SHOWING CONTIUESLY (ATTEMPTING TO A BOOT HARD DRIVE....)
44
Is there anyone who can help me regarding this HMI is missing the choices when I make a new Device in TIA. Only 7" Display above are the choices...
92
I have a German programed ME program. I want to know what tag in the PLC a latched button turns on. However when I open up the tag properties I...
229
We are considering dropping our UL membership because most of our customers do not care if we are a 508A shop. However, there may be times when a...
420
Hello, I need to create an automatic transfer panel that connects to the generator when the mains power is cut. I can draw up to 60kW and draw up...
96
