Simatic MPI or Profibus packet sniffer?
longsoul
Jan 2013
FAR AWAY
Hi to all
How many of you have had to replace a still working hmi with a different model in a system without having sources?
Well, in my experience, I have to obtain good patience and during stop production times, have to carry out many tests.
Is there a way to record all commands and requests that an hmi send to PLC?
any practical example? ;)
thanks
One other thing to keep in mind is that while the HMI is communicating to the PLC via the same physical medium as Profibus, it probably doesn't actually talk Profibus IO (it isn't a profibus slave). They usually use S7 communications to make data requests from the PLC (PUT/GET style), and so you need to make sure you get a profibus analyzer that supports it as well.
Hello
Profitrace (www.procentec.com) is a tool that records Profibus frames.
In the past in similar situations we read the PLC code carefully and understand what part does what. Then you can monitor DBs while someone operates the HMI. This may work for a small project.
Hello! I'm trying to use one PG/PC as a gateway between a PLC and another PG/PC. I've been trying to follow this guide...
4,504
G'day, I was wondering if there is a solution to this problem I have. We have a production line with 15 Siemens PLC's. They vary from S7-313C...
3,503
Hi all, Can any of our Siemens experts, clue me into how I can use my PG [Laptop] and my OP connected at the same time to the CPU on a MPI...
8,908
Hi all, Does anyone know whether it is possible to Monitor/Program the PLC prog thru the OP3 to the S7-312. As in all connected and PC attached...
4,833
Hi all ! Here is equipment and Sycon-software for Simatic S7-MPI connections from PC's Ethernet connector. Cable must come from HUB or Switch or...
1,757
