Simatic Net 6.2 Sp2 on XpMode
Longhorn
Jul 2008
Scotland
250
has anyone successfully installed simatic net on xpmode in windows 7, i keep gettin an error about installing it from a remote session.
Any Ideas??
I had a problem installing siemens until I put the DVD in or copied all the software to the virtual C drive and installed locally as per say then deleted the installation files.
I also had to play with settings giving myself 1024mb and setting the lan connections to the correct ethernet card in my machine. I was surprised it wasn't transparent. I also downgraded automation licence manager to v3 not v4 as it didn't license properly.
All working now though.
Best to install locally so copy from your network to local drive install and then delete installation files - this worked for me not sure why though.
Does any have a fix for running "simatic net V6.2+SP1" on XP Pro SP2, i.e apart from buying the latest version
5,449
I don't know if this is the right place for the subject at least I'll try. The company has one of the oldest computers that is a master Windows...
758
I had a system running WinCC v7.0 SP3 and SIMATIC Net V8.1 SP2. The WinCC Runtime project was reading symbolic tags (e.g. D435.HMIVars.Start) from...
1,699
My problem is that I can not approach variables from OPC Scout 10. I can see Data blocks but not variables. I'm using TIA portal v14, SImatic...
2,906
Hi I need some help!! Siemens Simatic Net 2006 cp5611 has been discontinued, I have a PC with a dodgy hard drive so looking to do a new install...
1,686
